Sliding Door Central Locking
Brian1852
Hi,
I have a 2018 Kombi with twin sliding doors and would like to introduce a switch to isolate one of the sliding doors from opening with the key fob while camping. The reason is so we can have our table and other stuff against that door and it won't get accidently opened after a few drinks (yes I've done this more than once).
Has anyone already done this that could give me some pointers to save some time?
Hi,
If anyone is interested I’ve successfully achieved this by removing the door card and cutting and introducing a rocker switch to the solid brown wire. Now when this is switched off all the other doors and tailgate, lock as normal but my sliding door doesn’t. I’ll leave it switched on while I lock everything and then switch it off so it no longer unlocks. FYI the soft close motor ( not sure if that’s the correct technical term) works as normal regardless of the position of my new switch. Hope this helps someone.
