TriggerBoi
The RH electric sliding door on my Multivan intermittently reverses while closing — sometimes straight away, other times just before latching. It closes smoothly, then suddenly triggers the safety reversal and flies open again.
Tracks have been fully cleaned and lubricated; I also found and replaced two loose bolts in the hidden rear track (Loctited), but the issue persists.
I suspect a faulty pinch sensor in the door seal. I’ve got a multimeter ready but can’t locate the sensor wiring or connector — any pointers?
OBDeleven shows door-related errors but won’t expand them. The dealer was no help (missed the loose bolts and only “cleaned” the tracks).
Any advice on testing the pinch sensor or known wiring/module faults would be much appreciated.
