The Bidirectional Sensors can be mounted on any side.But the question is, will these Caddy sensors fit T6 and are the plugs the same?
Caddy uses the same sensors on both rear wheels and T6 has 2 different kinds on either side. Mounting bolts are the same
I have this:Just found this .
and this oneAdapter Wire Module 1k8919472a Set 1k8 Radio - Sockets Car - AliExpress
Get set at a bigger saving. It is used for the upgrade and the new module. Find products of automobiles parts accessories with high quality at AliExpress.www.aliexpress.com
25.6ï¿¡ |For VW PQ Platform Car Install MQB PDC Parking OPS System Adapter Wire 3 To 2 Connector Cable Harness Golf Jetta Passat Touran|Cables, Adapters & Sockets| - AliExpress
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
Your link doesn't work for me.
Thanks for verifying that .Ok, we got a bit setback.
Today i tried to change the ABS Sensor to the WHT 003 864 A
That did not work, they are mechanically to different.
View attachment 68805View attachment 68806View attachment 68807View attachment 68808View attachment 68809
Thanks.Thanks for verifying that .
I owe you 50% of your costs.
By the way, nice new brakes!
Coding needed is 0x50.So WHT 003 856 B and WHT 003 857 B are the right sensors?
Yes, rear is enoth.Great news!
Do we only need to change the rear ABS Sensors?
