Shuttle drivers side sliding door card removal
Joystick
Can any help with instructions on how to remove the drivers side (T6 shuttle) sliding door, door card? Does the door need to be removed to do this?
The door has a rattle and apparently you have to remove the door card and cover the fixings with tape!!!‍♂️
Any help much appreciated as I can’t stand the rattling on a 2000 mile summer holiday!
It’s just clipped on. A straight row of metal clips along the top and 10 or so plastic pop clips around the edge. You might need to slide a trim tool in to release the pop clips
The door doesn’t need to come off, slightly open it and start in the bottom corner with a trim removal tool and work your way around. I have just removed two and remember to take your time, I removed the seat and sat inside whilst a friend held the door slightly open. Once a few poppers have released you can pull gently as well, also looking behind the panel to see where the rest are located, leaving the side nearest the back until last.
Can anyone help please as I'm having trouble getting the sliding door card off from my shuttle.
I've managed to unclip all around but the door card still won't come off. Have tried pulling in various directions but seems stuck along the top edge where the blind is.
There is a row of metal clips along top edge. They can be quite tight. They are the same as the ones going around the top window trim
On the door card side, are those metal clips attached to the blind housing, or the door card itself?
When im pulling on the door card, it feels like the door card will separate from the blind housing.
I found this thread as was having the same problem. I've made a video which I hope helps others get the door cards off. If anyone can help me solve my locking/unlocking issue, I'd appreciate it.
