Sca Rear Opening Roof Catch Broken
Mick
Hi,
Just back from Austria after a great week in the van. Moved the catch to open the roof and it just moved and nothing happened.
Now it is loose and roof iOS secure.
2 questions:
1. how long is the warranty on the roof - any clues
2. Anyone have any idea how I can get it undone to see if I can fix it? It has about a number of screws in the housing but I'm not happy about undoing them.
It moves loosely to the right but won't open to the left. I don't seem to be able to load a vid onto here. So here is a link
SCAROOF
photo attached.
Hi,
2 questions:
SCAROOF
photo attached.
Hi sorry I can’t comment on the problem you have but do you find the two roof catches rattle when going over potholes in the road?
Hi,
2 questions:
SCAROOF
photo attached.
2 year warranty i believe, sonds like you need a new catch.
Hi, see attached, the handle is moulded to an insert which is bolted from the inside of the mechanism, image 1 shows new handle, image 2 shows where the handle has come off the insert. You should be able to dismantle and find out what is going on. Sounds like the cables are not being activated when the handle is moved, or the handle is spinning on the insert bolt. If latter, pull handle off and turn bolt with a spanner.
Rgds
Ian
Eclipse Campers
yep it was a loose bolt. Thanks Ian.
