Running Usb Cable Into Glove Box On Comfort Dash?
In a state
I like a good length in a Van...
On my T5 I ran my usb cable though the top of the air vent and into the glove box to connect to the head unit. Is this still possible on a T6 with a comfort dash? Mount will be in the same place.
View media item 1636
There is a route through but it’s a bit tight getting past the radio, think you may need to remove the radio fascia trim
Is the top tray removable like the T5? Haven't got the van yet hence the questions...
There is a small space at the from of the top box to run a cable under.. I have taken mine out so can take a pic later if that helps?.
As long as I can feed a USB cable through to the glovebox it'll be fine...although I guess I need to make a hole into the glove box....
Think you could pop out the usb insert and cut a little slot out from the existing hole to pass the cable through
