Rocker Switch On Dash...
CALLAKN
Electrician / Linesman
T6 Legend
I’m sure it’s been covered a million times, but what’s the best switch for the job?? I’ve got a couple of 20mm rocker switches but think they’ll be too big ??
Ahh slick that’s what I was thinking about doing. I was wondering what diameter to go with and now I know. Thanks very much
I drilled out to like 13mm, then used my dremel to slowly sand-down the plastic hole to widen it enough to push the switch in
5FE7AAD4-FF61-4BA0-88AD-B03B53794496.jpeg CA786CE0-DC9A-44D7-B50B-3116783A15C9.jpeg 50E0835C-5640-4CA8-80D6-83389B573A65.jpeg 5C922C10-0E1F-46EC-A82F-59E63BB38A52.jpeg 880A9962-7CC3-44CF-A185-38BCE908A21A.jpeg 9CA36973-6BD4-49B5-BA34-FF7F20A1F318.jpeg 0208154C-C1FE-4ACC-8B69-DDE0CCA46095.jpeg 33C523E7-3F76-4495-919F-CE625285C63A.jpeg 8375D30D-E182-478D-89A8-53CB15A08901.jpeg 7E129C43-CADE-458E-B957-7D3B9D4D1C9D.jpeg Well switches have arrived and for the money they seem pretty good. But they are going to be just slightly too wide to fit / drill into a switch blanking plate. I definitely need one that is no more than 16mm at its widest point. CA786CE0-DC9A-44D7-B50B-3116783A15C9.jpeg
Pack of spade connectors £4.05 from Toolstation. And fit perfectly onto switch terminals. Although I would recommend heat shrink tubing to provide insulation.
Looking to install a switch in the same place to switch head unit from starter battery leisure battery so it can be used when camping, what amp rated switch should i use for this as the only 16mm ones I can find are 3 amp
I'm not sure it's that simple. I think the radio also gets a signal from the bcm.
