I stupidly let my renogy 100Ah battery go flat but I was able to charge it back to 100% using battery charger. The solar is now sufficient to keep the battery charged, which is only running the fridge. Day to day everything seams to be working fine (lights, heater, fridge etc)
I have a 1000W inverter attached. I can boil a kettle which is 700W perfectly fine, but my 900W air fryer isn't working. The inverter beeps at me now. I used to be able to run it and all other loads have been removed.
I can run the same inverter and the air fryer using a different battery. So I assume the Renogy battery can no longer supply enough amps.
Could it still be in a safe mode and somehow reset or is it broken and need replacing?
