Reimo multirail with Fiamma45s
oiu82
Hi everyone, I have a bit of an unusual question and could use some advice. I currently have a Reimo Multirail awning installed on the left side of my van. I recently got a Fiamma F45S at a discount (by accident!) and am wondering if I can install it on the same side. Do I need to move the Fiamma F45S to the right side, or is it possible to install both on the left? Any help would be appreciated—thanks!
Hi, assuming you mean a reimo awning multirail on the side of the van rather than an actual awning? If so, yes the Fiamma can be fitted on the same side. You can get mounts to do this - a web search should identify them - or you'd have to fettle the standard brackets yourself as it is not the original installation method. The rail will be in the way of the standard brackets. The installation probably needs to be 'non-standard' anyway if you have a pop-top. It all depends on your willingness to drill holes in your roof.
Hiya I think I have the fiamma bracket for this..I bought the wrong ones for mine, they are to fit a van with multi rail I will have a look at the box tomorrow !
The brackets I used are these.
T5/6 Transporter Fiamma Reimo F45s Awning Bracket (98655Z156)
I purchased them from Clearcut Convertions.
I have LWB T6.1
Reimo Multirail
F45s 3Mtr
Skyline Aurora Pop Top
The rubber on the poptop deflects around the brackets ok.
I got same kit as a part of my fiamma, was for free.
Most people buy a specific fiamma f45 t5 kit so you would have got the brackets not free but included in the price probably.
I already have the f45 awning on my t4 that I’m moving over to my t6 hence buying the brackets as they not the same t4 to t6..well hence buying the wrong brackets it turned out but hey I have them now so all good
These are the standard brackets. They will not work with a Reimo Rail fitted on the same side as you want the F45s
I don’t have a rail at all so they were no good at all for me I bought completely the wrong ones..I had to buy the correct ones..they are listed for sale now though hopefully someone might need them for their set up !
