D
nice one, so is there a need to use primer ?I think the sika is only there to seal the rail to the van. The screws hold it in place.
Is this stuff from screwfix ok for sealing the reimo rail ? Whats the difference between the sikaflex 221 and the stuff that screwfix are selling ?View attachment 48258
Yes i have watched that, unfortunately i think Rob uses sikaflex 221 but the stuff i have seen at screenfix is sikaflex but a different type. He also uses primer , whether that it necessary i am totally unsure? If the rail is held down by screws then why is primer required?is this any good to you?
Yes watched that one too, i see they also use primer. The sikaflex flex primer is £35 a bottle from kiravans. Does anyone know of a cheaper primer thst will fo the job ?Not actually done it myself as still waiting of delivery of my van... also had this video - which you may have already come across...
Fair pointI've bought the correct sikaflex and primer from kiravans, can't see the point in skimping on something so important.
Re. the screws, I'd say they are there just to hold it in place whilst the sikaflex cures and the bond is where the majority of the strength will be not just a few self tappers.
Screws are required to flex the rail to the shape of the van. They come straight.Do people really screw these straight onto their bodywork??? I cringed at the thought of it. Surely sikaflex will be enough?
You'll be disappointed thenI'd expect a proper shaped rail that doesn't require me to screw into my bodywork for £200![]()
