Recessed fridge in wall
Badjamin
Live long and camper!
T6 Legend
I have perhaps failed to look before I leapt with this...
Has anyone got a recessed fridge setup so the units are flush?
I have bought an interior unit that requires a cut out into the wall of the van and I foolishly assumed I could buy a standard fridge. The fridge is in transit and now I've checked the cupboard it looks like a bit of bulkhead is going to clash with the 500mm depth of the fridge by approx 40mm
Assuming I'm gonna have to send the fridge back now 🫤
Not sure what’s behind mine but my fridge is basically flush. I think it depends on the cupboards though, what size bed have you got the cupboards to fit? A 112 rib should basically fit the fridge in flush although it does use the space in the side for ventilation. I think it might not be square at the back so could avoid this being an issue
Edit: sorry that door definitely wouldn’t fit though
It's a 112 Rib that I've got. I'm hoping it's not square at the back. JustKampers are closed til monday now so am stuck til then for infos.
Let this be a lesson to others, don't buy fridges in a rush whilst not wearing your glasses and getting the van cleaned...
I think I've messed up even more as the fridge door handle sticks out and I'd likely need it to be flat to get it behind the door. Ooof... this is excruciating. So glad I made this public 🤣
It can’t be set in flush or the door won’t open.
All fridges have manuals with the minimum clearances to allow convection heat transfer.
Make sure the van body behind the fridge is very well insulated or the convection will be coping with the ambient solar radiation not the fridge heat transfer.
The door will open if set flush (to the face of the cupboard, not flush to both side panel uprights) as there will be a 20mm gap hinge side to allow for the 'outswing' this is how flush units work I believe or how i have seen them work. 100% agree with you about insulation - not sure how I'm going to accomodate clearance at the back as well as lots of insulation and ventilation and also the sticky out handle thats gonna stop cupboard door closing... what a mess
The door will open if set flush as there will be a 20mm gap hinge side to allow for the 'outswing' this is how flush units work I believe or how i have seen them work. 100% agree with you about insulation - not sure how I'm going to accomodate clearance at the back as well as lots of insulation and ventilation and also the sticky out handle thats gonna stop cupboard door closing... what a mess
Depends if you want to open the door 90 deg or 180 deg.
Most fridges need open 180 to get the shelves and freezer box out.
Fair point.
I'm gonna send it back and get a thq fridge.
(Alpicool CR50X)
Just arranging to return it to just kampers at cost. Meh.
I've contacted transporterhq for some advice and am waiting to hear back before I buy one of theirs.
The lovely forum member I bought the interior from seems to recall the depth of his fridge was shorter depth fridge by dometic but I can't find one less than 480mm.
Watch this space I guess
I'm thinkin perhaps I just take cupboard door off and hack the top off it to make a blank above fridge and have fridge sticking out 25mm... It'd clear the RIB when its out.
Have you thought about a top loading fridge? We have one in the new van and I love it. Never an issue with access no matter whether bed is set up or where seats are. You’d think it would be harder to fit stuff in but I think a lot of space gets wasted in a normal front loading fridge. Fridge is behind the panel next to the drawers in the pic, with a lift up part of the worktop to access it.
Fair point.
(Alpicool CR50X)
Be aware that the THQ fridge needs to sit proud of the face of the units for it to open.
It opens from both sides.
My fridge was upgraded to the THQ which is fantastic BTW but it has to sit out about 50mm because my unit is tight to both sides of the fridge.
Im going top loader this time :thumbsup:
