After receiving my converted 2017 T6 Highline Panel Van back from the Converters, the rear view camera and parking sensors no longer work, with no info appearing on the radio display. (It’s just the standard VW radio unit). When I engage reverse I just get one long beep – and that’s it. Seems too much of a coincidence that it’s stopped working following the conversion so I have to assume something untoward has happened there. If a screw shorted out the parking sensor feed, for instance, might that cause the BCM to disable both the parking sensors and the camera? Should VCDS give me any insights into what’s wrong?
Would welcome any clues as to the cause of the problem. Thanks.
