Rear Self Levelling Sensors
michael thorpe
Hi looking for some information of where the cables run for the rear self levelling sensors to see if its posable to run them in a fully converted camper van.
Would need to have air suspension surely?
Edit: or do you mean for the LED headlights?
We had the LED HEADLIGHT upgrade on our last T5.1. Both axle sensors were mounted on the drivers side of the van on the lower suspension arms.
The cabling was run externally allong the underneith of the van tied in behind the under body plastic covers up to the new module.
The passenger side light was cabled back to the drivers side light allong the front slam panel under where the bonnet catch is.
There are 2x entry holes. One was under the passenger bench seat base. And one was through the firewall.
From memory we had the auto lights added too which involved the new light switch..
Oh we had the HEADLIGHT washers added too.
It was all done by hadzydazy and took about a day.
The new modules needed coding obviously.
hanks from what i can see there is 4 on the T6 and the rear ones look like they go in through the back wheel arch liner will give them a call see what they say
Thanks Pauly just seen your reply i will PM you my number and if you can phone tomorrow that would be great working offshore just now but will be home tomorrow about 16:00
FYI - just checked our factory fit LED axle level sensors.
just one sensor on each axle , one front, one rear, mounted on the drivers side of the van.
