Propex heater not firing
Lorp
Hi. I have an underslung propex heater with digital control panel. Haven't used it for a while. Now on a cliff in the van and could do with it! There is no red led light coming on so no warning light. Any ideas? I've got plenty of gas and gas rings are working fine. Thanks
Provided the desired temperature exceeds the current temperature, and that you’ve got the fuel display switched on, then it should fire up.
If you’ve not got yours, do you want me to send you photos of the user guide? That might have something in there that you’ve missed?
Edit: found a copy of the User manual
  • Propex HS2000 (April-2018).pdf
