Prime Water System
orcades
Hello All,
Got a problem the water system in an Autohaus T6 Camper conversion.
Basically because weather was so cold in north of Scotland I drained the water tank to prevent freezing. I then filled it up and there seems to be Air in the system.
Google search seems to suggest the best way to prime pump is to disconnect the output hose from pump and raising hose above pump and priming with water poured down hose, then running pump to remove air.
Is there an alternative way,
