Pressurised Water Sprayer
Got a similar thing I use for a shower (after a day on the beach) works same way
I boil kettle boiling water and add to a bucket of 15ltr of cold. Drop pump in pull trigger and off ya go. Magic !
I want to have access to a water hose that powered and supplied from the as yet to be defined or decided upon water tank, (inside or underslung).
Ideally the hose and spray gun can be removed for storage, the location of the access point to be at the rear of the van.
Is this the sort of contraptions you [the masses] have used for this purpose?
https://www.amazon.co.uk/dp/B07BS76Q1S/ref=cm_sw_r_em_api_i_c_ew6sEbKG3KDSF
I got the exact same one off eBay a couple of months ago (£17.99), I used it a couple of times and have now upgraded to a Worx Hydroshot because the eBay one packed up :(
A mate runs a Worx hydroshot but dont buy in the UK they are not the best avalable. Buy the US version which is 2x 20v batteries making it a 40v system. Add 4ah 20v batteries and you are laughing. EU and UK has not received the 40v system yet and it will probably be another year. The difference is worth the money but compare the 20v to the £20 ebay jobbie and its amazing.
