Pre-purchase check: error codes MY2020 T6.1
BlakeyG
Hi All, hope someone can help and provide a bit of advice.
I've just had a RAC code check on a T6.1 i'm about to purchase. It came back with lots of error codes as follows :-
ABS
1141 (intermittent)
1209 (intermittent)
Auto Distance Regulation
1289 (intermittent)
2055 (intermittent)
2068 (intermittent)
2101 (intermittent)
2111 (intermittent)
928 (intermittent)
Can Gateway
131602 (intermittent)
8531970 (intermittent)
Electronic Fusebox/distribution Panel
B14D154 Front window regulator, driver side No basic setting (intermittent)
Information Electronics
1637 (intermittent)
Parking Assistance
U112300 Databus error value received (intermittent)
Telematics Communication Unit
B2000049 Ctrl. module faulty (Present)
U111100 Function limitation due to missing message (intermittent)
U140000 Function restriction due to insicient voltage (intermittent)
This will be my first VW Transported (I've had old beetles before :) any advice will be most welcome if any of these are a major problem before I purchase.
Many thanks Gareth
Searching the codes on the forum will give you a steer - IE searching “ABS” and “1141” came up with this, so you might find some are generic whilst others indicate deep / serious problems
reset the steering angle sensor - that should clear the ABS/ESP codes. (1141 - Implausible Data Received from Steering Angle Sensor Module (G85) (U1123 00 [009] - Received Error Message[FAULT_ESP_STATUS_SYSTEM])
U1122 00 [009] - Implausible Message
[FAULT_ALP_STEERINGWHEEL_INIT])(
16128 - Steering Angle Sensor
B1168 F2 [047] - Not Initialized
charge the battery - should clear low voltage issues. (27277 - System Voltage P0562 00 [035] - Too Low)
reset the window pinch protection. (592133 - Window Regulator; Front Passenger Side B14D2 54 [009] - Missing Calibration / Basic Setting)
but what i would do first is a full reset . . . then do each of the above.
Oh and welcome to the forum!
Thanks for your help, much appreciated
