My battery nearly died the other day, since then I've had the left hand door illuminated on the door buttons.
From the inside, I can open the door manually but if I try to open the door from the fob, button on the dash or outside handle - nothing. It only works if I pull the 40 amp J fuse underneath the passenger seat and slide it manually. But even then, the soft close doesn't work if it's in or out.
If anyone has experienced this before, please let me know what worked for you.
I tried leaving the fuses out for 2 days, but nothing. It's weird the outside handle doesn't work either regardless of the fuse being in or out.
