Nosnittap
Since I took the male plug off the rear ceiling light to try and add LED lights to it.
www.t6forum.com
In the beginning the led lights worked I attached to it but the lights in the cab didn’t work anymore. The last time this happened was when I took the knock plates off the rear doors. Can anyone help me.
How to connect led to existing loom as courtesy lights.
I’m trying to add courtesy lights to exiting loom but the old courtesy lights had an on and off switch but these don’t. The work but stay on while driving and the only way the on off switch works in drivers seatbelt column is if you hold it in. There is also a light on the dashboard. What do I...
