Passenger Seat Fuse Box Connector Part Number
DubHaus
Indium Grey T6.1 T32 Highline Kombi - WIP
VCDS User
Hi, can anyone let me know the part number for the fuse box terminal connectors (the part the actual fuse connects to) for the under passenger seat 12 way fuse box please? Not sure if some of the MTA terminal connectors will suffice? TIA Nick
There is no part number as VW dont sell them anymore, there are two sizes of connector for fuseboxes for small or normal blade fuses
Search JPT or junior power timer and you will find the smaller ones and that should lead you to the larger ones
The only other option is buying repair wires from VW which is a crimp connector terminated onto approx 300mm of cable that can be cut and joined if required
Will see if i can find some links
Heres a couple options but these ar edesigned for waterproof connectors so use the rubber boot at the rear
and some more
