Particulate Matter Sensor
BenWomersley
Had a warning light and error code P24C600 (particulate matter temperature sensor failure)
2019 T6, CXFA 150hp
I have bought a replacement sensor:
04L906261F - Bosch 0281007046/047
it has arrived today and I have just double checked compatibility to see that it isn't compatible with pr number 7CS. Just checked my data sticker to see 7CS.
I can't seem to find an appropriate replacement sensor. Apparently I am looking for:
04L906261G - Bosch 0281007405/406
Can anyone tell me where I might be able to find one / if the one I have will work? Everything I have read suggests the 'G' version is a slight update and is backwards compatible but can't see the 'F' version will be forwarded compatible.
Thank you!
See this thread -
Did you check what version your current sensor is? It is likely version F anyway.
I read that yes: they didn't say if they had the 7CS pr number so wasn't sure if theirs would be happy with the cheap(er) and available unit and mine wouldn't.
I haven't no, I will try to pop my head under shortly and see
