Particle sensor fault
juggy1
Can anyone help , I have a 2019 t6 with 29670 on the clock and it’s 14 weeks out of warranty! Had the engine light come on p24c600 passive /sporadic particle matter sensor circuit and passive/ sporadic particle temp sensor temperature circuit , reset went off for two weeks now back on reset and on following day also noticed the adblue counter stuck on 5000 miles and no dilution figures ? Guessing the sensor has had it . Rang vw been given part no 04L906261G but non in stock everyone else I ring says it should be 04L906261F which is about £140 cheaper does anyone know the difference even the bosch website doesn’t recognise the G one ?
Hi...part with "G" is relevant for engines with better emission standard class like "6", those with "F" might be for emission class for older vehicles. That's what i found out when i had to buy a new part. i have a VW T6 2019 and it has "6D-Temp2"emission class. My car definitly needs the part with "G" at the end. its sad, that currently you can only buy original part from VW. This sensor comes with control unit. Probably the control units from "F" and "G" are the same, but with different software.
