Part Number - overhead console Cali
Eclipse Custom Vans
Van Specialist. SOLOW, REVO Dealer, Conversions
Trade Member
Hi all, Im trying to find the part number for the small rectangle panel in the image but without the sun roof controller in, so just a plain panel. Its from a T5 Kombi, but also similar in shuttle. We have not got another van here with the same headlining to check. Thanks for your help.
I did have the part number your looking for but after a quick look cant lay my hands on it.
The part number you are after only appears on shuttles and caravelles as only kombis with sunroofs got tat particular moulding on sunroof vans.
If your fitting an SCA roof to a sunroof specced Kombi frustratingly VW dont produce a headliner for commercial spec vehicles that fit that moulding without the sunroof profile. So you either have to re use the sunroof compatible headliner and do something at the front of the van to sort the opening out (which looks a bit naff) or use a shuttle spec cab headliner and replace the upper and lower b pillars to get a nice finish where the headliner meets the b pillars. This does throw up other challenges around the top of the b pillar area but looks a lot better. I hope this helps @Eclipse Campers
Cheers mate. Yes fitting roof, filling in sunroof etc. Headlining tricky and yes shuttle one doesn't fit exactly with standard b pillar covers. Never straightforward......
