Oil Pump upgrade and balance shaft delete kit
  • Thread starter Thread starter Lux
  • Start date Start date
Lux
Hi all,
I own a T6 w/cfca engine.
I went to order a new oil pump and hex drive shaft from the company MMHP, I had read a few good things around regarding their shaft upgrade and thought I'd just do both whilst I'm in there (just preventative as it has just hit 150k km) and they have emailed me back asking/suggesting that I look at spending a bit more and buying their upgrade kit in particular the stage 2.
Has anyone installed this upgrade kit? I believe it deletes the balance shaft unit aswell. It may be another VW oil pump just packaged nicely as a kit for ease of install.
link to unit Upgrade Your 2.0 TDI Engine - Remove Balance Shaft Module with MMHP e
I understand the oil pump in these engines is a bit under whelming for the heat and stress the engine gets but I haven't had any issues with the stock unit. I do have a tune on the van and also have a front mounted oil cooler, Ido a bit of towing, use for work and also a bit of camping so it gets a good work out.
Thank you for any info,
Matt
