I'm feeling quite lucky and don't want anyone else to make the same mistake....
On the I’m just back from a trip to the Alps and on the way home was having an early morning brew (1kW Kettle) at the same time as having a 12V fan heater on (only 150W) I suddenly had a rather unpleasant smell, but mercifully no more...
I’m pretty sure I know what has gone wrong, but would really appreciate your comments, and would NOT recommend anyone doing a similar install…
As you can see from the above (and below) I had modified the box to get its input through an extended bolt…
This worked fine on initial full load testing and I didn't detect any significant temperature rises...
However I think this was the mistake... as it ran warm enough, on all the many previous brews, to soften the plastic enough to allow the nut inside the case to pull back into the case.
This left the nut clamping the fuse then loose; the resulting bad connection became a bad connection and instant hot spot with about 90A flowing.
Maybe if I'd put a sold brass spacer right through it would be fine, but I'm planning on a more traditional cable entry on rebuild.
PS the cuppa inside the van at 6am whilst at -3C outside was just great; so no comments on using gas to boil water please
