yeh, 100% defo,
we've had this with other members . . .
basically the vans "power management system" wont account for any power thats drawn by that tow bar kit.
and can lead to messed up battery charging and a flat battery.
it's an easy fix, just move to chassis ground, or fit a chassis ground busbar . . .
The manufacturers install guide is correct for NON-STOP/START cars/vans.
On stop/start like the T6, ALL -ve/0ve/grounds must go to the chassis ground and NOT go direct to the battery.
This is so the battery monitor can correctly monitor the power in/out.
its called "bridging out the monitor" and should not be done . . .
the cover gives an indication to this issue to . . . . . about NOT connecting battery chargers to the battery NEG post, but to use a body ground instead!
My issue with this is the VW have NOT provided a ground post near to the battery for this purpose (like most other manufactures do)
more info on it here:
Battery Charging - Main Battery Earth Point - so weve all be told NOT to bridge out the battery monitor on the neg side of the battery when charging it. This is so the ECM can correctly gauge the SOC (state of charge) of the starter battery by monitoring the current flow in and out of the...
www.t6forum.com
Battery Chargers - How I Did It - So its that time of year again, cold, rainy. . . . . . . flat battery =[ This time we look at Battery Chargers. Our vans will most likely come with a AGM style starter battery, for this type of battery we need a "Smart Charger" . . . . but what does this...
www.t6forum.com
Advice required. Hi guys - I thought it would be prudent to carry one of those small JumpStarter powerpacks about with me as I have an electric lift seat installed for my better half and am a little concerned that with the extra demands on the van battery I might get caught out one wintery...
www.t6forum.com
FYI, this is the battery power monitor:
