Hi there,
ok so i've been trying to find time to do this, and i have finally managed to get the front bumper changed with the fogs etc with the help of @Pauly amongst others..!
I've got a potential window tomorrow night.. or sat am v early.
I just went to the van to check everything out again, and i got to the bcm and to find pin 17 on the white plug... can anyone point me in the direction of how to find it?!
I can see easily 1-16, then if i try to slide the plug apart i think i can see 35-37?? but tbh i cant see how the thing splits apart fully
This got me thinking - the loom that i have from vagnostics is two cables, 3 pin connectors.
1 from pin 9 on steering wheel module to the light switch 12v
1 from pin 10 on steering wheel module to the famous pin 17...
So the 9 and 10 are plug and play - the light switch is a crimp fitting or solder.. this leaves pin 17 - will it be empty so i can just plug and play again? or am missing sth?
@Deaky do you remember by any chance? Pauly - do you know? or anyone else?!
Thanks a million..this'll be my last mod for a long time!!
edit: i think i've just found it on a pic pauly sent me...its right at the other end from 16.. b**ger.. i dont know about a RHD but the LHD bcm's area pain to get to, even removing the both of them there is zero slack..
