Maxton V2 Splitter (Textured)
Yzfr1
Hi,
Has anyone here fitted the Maxton V2 splitter that's got the textured finish?
I was wondering if the textured version is a good mach for the OEM plastic parts.
I not sure if a gloss one may look odd against my OEM unpainted plastics.
Is the commercial bumper the same finish?
I have a painted bumper......just the inserts are std textured finish.
I’m not 100% sure, I thought they were the same finish with the textured nobbly bits. I know people sand them off when they paint it up but I don’t know it’s the same finish as the highline style grills. They have a slightly different finish on them though anyway
That's what I'm worried about.
Do i get textured and it doesn't match the rest or do i go gloss and not let my ocd eat me alive looking at three different finishes on the front bumper...... :confused:
No, I mean the highline grills are different, some are textured some aren’t. I think as long as it’s the same grey it will be ok and you can use some plastics restorer to ensure that.
I think it’s a good idea. It’s better than fitting aftermarket gloss black grills
If you have all standard textured black plastics on the front end and add a gloss black splitter it just won’t look right. You’ll always notice that it doesn’t match the rest of the front end plastics.
I would go with the textured one, even if it isn’t a 100% match, because it’ll always be better than having just one gloss black item on an otherwise matt/textured front end.
I’ve seen a van with a textured black splitter from van style and it matched well with the textured high line plastics, it looked very good as a combination.
They aren’t going to sit directly next to each other either and at a completely different angle so you can get away with any minor variation
Think you are on my same wave length......ill go check on the van style one out now!
This is mine before I changed the grills and I don’t think it looks that bad.
The other option is to go carbon fibre
They don’t look great on their website, but perhaps @T6180 could share a pic of his front end to show you the overall look.
Your right.......it doesn't look great on their website. Looks like its just filled a space. The height of the van doesn't help the pic though.
Colour match/texture looks very good though.
