Looks like you're running 20's there so the max you can really go while keeping the standard shocks is -45mm springs. These will be a little crashy with the 20's but not too bad but are very much at the compromise end of things. To get excellent ride quality you need to spend decent money and look at matched springs and shocks kits like Koni, H&R, Bilstein or quality coilovers from the same names and SoLow which have 3 different offerings depending on what drop you want. If you go this route then worthwhile checking and replacing any suspension components not up to scratch like wishbones, tie rods, bearings, top mount, top plate, drop links and antiroll bar bushes. The use and type of van you have will help determine what you need, T28/T30/T32, camper, commerical etc. A word of warning ... if you go to all the trouble of replacing springs you might find that very soon the van still is not
Much appreciated Bent5Looks like you're running 20's there so the max you can really go while keeping the standard shocks is -45mm springs. These will be a little crashy with the 20's but not too bad but are very much at the compromise end of things. To get excellent ride quality you need to spend decent money and look at matched springs and shocks kits like Koni, H&R, Bilstein or quality coilovers from the same names and SoLow which have 3 different offerings depending on what drop you want. If you go this route then worthwhile checking and replacing any suspension components not up to scratch like wishbones, tie rods, bearings, top mount, top plate, drop links and antiroll bar bushes. The use and type of van you have will help determine what you need, T28/T30/T32, camper, commerical etc. A word of warning ... if you go to all the trouble of replacing springs you might find that very soon the van still is not low enough you'll be wishing you went for coilovers ... ask me how I know![]()
Welcome along, Straight in with one of the most debated topics in motoring history , well done ha haOk so this is my 1st post on here and need some recommendations about lowering, I don’t want to go crazy and lower it to much, just enough so there is about a 2 inch gap from top of tyre to the wheel arch, thanks guys
You dont need a coil over kit to do this well .
True but that assumes you're happy with the front height which is usually where the saga begins and later ends with the aforementioned coilovers![]()
Hello Iv found that the stance+ street or stance+ proline are great value for money I run 20s on mine and it’s quite low on 255/35/20s and it’s not that bad befor I put them on it was on hr lowering springs with standard shocks when I first swapped them over I had it around 50 mm Lower and it drove same as it did on hrsOk so this is my 1st post on here and need some recommendations about lowering, I don’t want to go crazy and lower it to much, just enough so there is about a 2 inch gap from top of tyre to the wheel arch, thanks guys
Thanks budThat looks quality bud thanks for the pics nice bus![]()
Yeah 18s think I messed up, thought it would be adequate@IanT6.1 What size tyres are those? They look to be quite a low profile for 18's on a van. That won't be helping with you arch gap.
Your van looks awesomeHello Iv found that the stance+ street or stance+ proline are great value for money I run 20s on mine and it’s quite low on 255/35/20s and it’s not that bad befor I put them on it was on hr lowering springs with standard shocks when I first swapped them over I had it around 50 mm Lower and it drove same as it did on hrs
Iv got the stance street on front which is £400 for full kit but found the rear shocks were not very good for my van as it’s a t32 and I carry weight sometimes do I changed rear for stance proline rear which are hight adjustable and stiffer the cost £199 but full proline kit cost £600 Iv had them on my van for a while now and haven’t had any problems other than the rear being a bit softer than I needed I know a lot of people go for the so low or van slamYour van looks awesome
I have looked at Stance proline and rightly or wrongly been put off by their cheap price, like I say, I'm really unsure of that's right or not but £400 for a full set seems ridiculously cheap!
Has anyone else got an opinion at all on the Stance Proline kits?
Also I have got mine very low iv got a machined top mounts on the front with t6 top mount bush which allows for anther 26/20mm lower and a rear adjuster delete with adjustable shocks u can buy the kits to go lower from transporter HQ they are really helpful tooYour van looks awesome
