Lee I've left Ed and slept in the van many time using the double key press. So it did work.AFAIK....
The second key button press ONLY disables the SAFE/DEADLOCKS.
Its shouldn't disable the ultrasonics.
Maybe you just been lucky before?
Loz it's just as easy to push the pillar button but thanks for the tip. It's just when you settle down for the night the double press is convenient.use the key in the lock, one left turn, will disable the sensors but leave the deadlocks on.
then if you leave windows open a bit on a warm day, no one can lean in and open the door.
The pillar button also turns off the deadlock, so not quite as secure.Loz it's just as easy to push the pillar button but thanks for the tip. It's just when you settle down for the night the double press is convenient.
i wonder why that is then . . . ?Lee I've left Ed and slept in the van many time using the double key press. So it did work.
On my way down to Spain I got up for a jimmy and it set off. It has gone off a couple of times since. Never did before.
FFS now I have to RTFM! I'll have a look at page 39. I do have factory fitted Safelocks and alarm.@Mick - do you have the alarm system and SAFELOCKs installed? (im assuming you do?)
likes like there is various behaviour depending on whether you have the alarm/locks combo fitted from factory.
The Book Of Knowledge - T6 - T6 Owners Manual
View attachment 142377View attachment 142378View attachment 142379View attachment 142380View attachment 142381View attachment 142382View attachment 142383
RTFM?!! Hand back your man membership card! No bloke should admit to RTFM!!!FFS now I have to RTFM! I'll have a look at page 39. I do have factory fitted Safelocks and alarm.
So RTFM. I was right. 2 keys presses disables safelock. Disabling safe lock deactivates the interior monitoring system.FFS now I have to RTFM! I'll have a look at page 39. I do have factory fitted Safelocks and alarm.
My copy and paste was from the online manual you recently put up using the VIN to login. i just cropped itThe online version is more up to date.
I believe that if you lock the van using the button on the inside of the drivers door (where the window switches are ) it locks the van without the deadlocks and without setting the motion sensors.Hi
I know this has been extensively discussed but still can't work it out any help appreciated - we have a 2019 Kombi behind the driver the pillar has a switch on it - I think this is meant to disable the motion sensors when camping in the van or leaving pets inside but wanting to secure the van overnight.
I cannot for the life of me work out how to make it work anyone able to help ?
We are about to go to France and we will be sleeping on our bed platform overnight and would very much like to be locked in !
If you push that one, with the drivers door open, then lock the van with the fob it will disable the motion sensors. However the deadlocks are activated.its that easy - thanks so much - so what does the button on the pillar do anyone ??
