Lighting gremlin
Fintious maximus
Hi all,
I replaced all the bulbs in my T6 a few months back and this week I’ve had the ‘blown bulb’ warning light on a couple of times. Each time I’ve checked the near side DRL is out but when I next start the engine the warning light doesn’t show and the light works as normal. It’s only done it a couple of times and both in the last few days. Is this just a gremlin or is there anything I could check. Thought about getting some contact cleaner on the bulb connector🤷‍♂️
I had ‘exactly’ this issue last year but with side light/dipped beam (call it what you will). When I parked up one day per chance I saw the bulb flickered on then off.
Investigated and turned out to be a loose filament. It was ‘making and breaking’ on the internal contact causing the ‘blown’ indicator to go on and off.
Might be worth just changing the bulb or wiggling the contacts of the wiring connection to see if that causes it.
In all my years of in-depth electrical and automation process fault finding the first go to is KISS. Keep It Simple Stupid 😆. Often it’s the simplest of remedies.
HTH
What van? T6 or 6.1
What lights?
If it is T6 with H7s it is probably the DRL holder.
HTH
Well this one was really simple stupid - dodgy bulb. New one in and sorted. In 40 years of driving I’ve never known a build to work intermittently. Confirmed it was the bulb by swapping over to the drivers side and it didn’t work there either. Oh well
So after swapping out both DRL bulbs last week for Lucas double life the bloody warning light came on again this morning on the way home from a couple of nights in York. Pulled in to services and replaced with a spare one and sorted. Am I just having bad luck or could something be causing them to blow? This one was the opposite side to last bulb that went bad but I replaced both
