leisure battery set up
toonaroon
Hi all,
I'm a bit to lazy and hot to look through all the post's on this subject, so I thought I'd just ask...
First Question, As anyone mounted a lithium battery on it's side under the drivers seat, I'm looking at thr Fogstar Drift 105ah, 260mm L x 168mm W x 209mm H
Last Question, I have watched countless video's on Liesure set up's, but I'm confussed about the main Fuse size, 50% seem to say 80ah mega and 50% say 30ah midi, I'm running 16mm cable, any help would be great TIA.
230Ah Roamer seatbase battery, Renogy DCC50S, Renogy smart shunt and an assortment of fuse types and sizes all under the drivers seat.
You really ought to take the time to at least speed through the various threads as it saves a lot of buying twice on such a scope creep type of project.
Hi all,
I could answer all your questions but I can’t be arsed….
Hi all,
Question 1 - yes.
Last question - it depends. And which fuse do you mean? Either way, fuse higher than max load but lower than the cable rating. The fuse is to protect the cable.
Question 1 - yes.
Thanks ginkster and all, just wanted to be 100% certain before purchasing 👍
