New Van - Existing Leisure Battery Set Up
Arronhughes
So.....I've finally gone and done it an bought a VW T6 Highline Kombi.
The van comes with a leisure battery already installed and is what I can only described as a professional job.
Unfortunately I didn't ask all the questions about it when I bought then van and I am now in a bit of an awkward situation where I want to add more to the van but I'm unfamiliar with the battery set up. At the moment it's located under the driver seat and a couple of usb ports and spotlights have been hooke up to it.
Any advice about how I should approach this and get to know my set up?
Cheers,
Arron
take some pics of your setup . . . .
the starter battery. . .
the battery under the seats . . .
any any other stuff you can see . . .
well have a look and see what's - what.
I've attached some photos of the set up.....hest I could do with it under the seat. Hope this helps. I just need to know how I go about adding more stuff to the battery and eventually a solar panel.
You should have som kind of an after market fuse box connected to the positive terminal on the leisure battery which feeds any usbs / lights that have been added. Solar panel can be added directly to the cetek
