Jarscott
Hi all,
I'm currently in the planning stages of my T6 camper conversion and working through the electrical system. I’ve attached below the diagram I've created of the layout I’m going for. I’d really appreciate any feedback or advice from those who’ve been through a similar build or have experience with this kind of setup. Currently thinking EHU under bonnet and under the drivers seat for Leisure Battery, Battery Monitor, Consumer Unit for EHU and Battery Isolator switch. Everything else in the rear cupboard.
Components in my system:
- Orion DC-DC 18A Isolated Charger
- Battery Isolator Switch
- Battery Monitor
- Battery Protect 65A
- Victron Multiplus 500VA
- 2 x Consumer Units
- 12V Fuse Box
- 2 x Bus Bars
- 4 x MIDI Fuses
- 1 x MEGA Fuse
- 100Ah Lithium Battery (likely a Fogstar 105Ah but not 100% decided yet)
- 12V Socket (for compressor coolbox – probably a Dometic CFX2)
- One set of internal lights
- USB Sockets for charging phones
- 230V socket via inverter for occasional charging of laptop
- 230V hook-up socket (non-inverted) for bigger stuff if required when hooked up
- Diesel Heater
- Another set of lights for a pop top (when we get it installed)
- USB socket in the pop top
- Does the general layout look right to you?
- Have I missed anything crucial or overcomplicated anything?
- 18A DC-DC Charger is shown in isolated set up but it doesnt need to be, I expect we will end up connecting it in a non-isolated way by joining the two negatives to a common ground as I've seen elsewhere on this forum. From looking into it I'm tempted to upgrade to the 30A DC-DC charger but is it worth the extra cost as we already have the 18A?
- Any recommended tweaks for future-proofing? Is it worth just accepting the pain of 30A DC-DC Charger and 230aH Battery now even though we only do weekends away?
- Suggestions on wire sizing, safety (fuse placement), or component positioning?
