Following on a bit from an earlier thread thinking I had goosed my LB and hunting for a replacement, spoke to the original suppliers who suggested a few things to test the LB first.
LB has a condition indicator, shows OK. Volts = 12.6v at rest. Suspect maybe not the battery at fault?
Problem i'm having is the fridge cutting out stopping, starting and giving the red light volt drop warning. This usually tells me LB is goosed. Current LB was the result of much research to get a good, powerful, semi traction battery that was perfect to start with, but now 3 1/2 years later and not much use thanks to covid and the fridge wont even do a full day. Everything else works fine (not much draw) and the battery shows well into the green on the van's in built battery monitor.
The battery has had 3/4 good 12 hour charges and wont run the fridge properly, but weirdly when used on the weekend, it played up in the day, seemed fine overnight and was still cold in the morning. Last weekend it played up all night so it got turned off as the stop/start cycle makes a racket.
It hasn't been charged since the weekend apart from a 2h drive home, and now 3 days later is still showing 12.6v. When it is cutting in/out it shows 12.6v perfectly fine on a tester but then when the compressor kicks in it drops down to 11.9v under load which I think triggers the battery protection on the fridge.
Pulled the fridge out tonight and reads 12.v at the terminals which indicates volt drop not an issue.
Any body with any ideas? I don't want to buy another battery and find my fault lies elsewhere...
Battery is an Exide 142ah ER650 semi traction deep cycle, good for 3-4 days happily running the frige when new. Fridge is the standard waeco cr 50.
Thanks!
Thanks!
