Left Hand Door Problem
ncpierce
Hi,
My wife's shuttle has an issue with getting the LH sliding door to shut. When I compare the back latch/slider mechanism between the two sides they are different.
Should they be the same...
This is the RH
and this is the LH
I'm guessing the bolt needs tightening and a new 'locking' nut installing...
So I have tightened the bolt back up. Does anyone know if the "lock" nut on the top is available on its own?
I don't think that's any particular locking nut I think it's just a thin nut you can tighten down to help lock.
Getting a spanner on to it is going to be a bit of a faff though I suspect.
So after the last time I found the nut on the driveway and reinstalled but without thread lock and now it has gone missing again…. I think it is this part no. N01111819 but cannot find a picture of it to confirm. Does anyone know what size the thread is on the nut? I think it is M8?
