LED DRL turning off with low beam
Matty2104
Hi guys,
After replacing a faulty BCM with a (second hand) one I am running into a few issues.
Originally when I switched my Full LED headlamps to low beam, the DRL LED strips stayed on.
Now they turn off and only the low/high beam stays on.
I hate this.
I have of course copied my original BCM coding from the unit to the new one, but it seems that it is not affecting the lights. The adaptation has no options to change that similarly to "dimming" LED with turn signals.
I have that option set on. This works as expected.
Not sure if connected to that, once I turn the main beam on, I get an error for short circuit on a Plus connector. I was not getting that with the original BCM.
And last but not least, now I am unable to adapt my fob keys at all. I have went through guides here at the forum, followed steps on Ross-Tech wiki, but the keys never confirm coding with hazard lights.
Would you have any recommendations please? I am tempted to try resetting the Byte 18 in 09 CE unit, but it set to my original value, so I see no reason to reset.
Thank you all
Is the BCM part number, hardware and software identical?
Hi Dav-Tec, thanks for you reply. Part number is the same, that was the main number how I was searching for a replacement. In VCDS the numbers are same in both, only the S/N is of course different.
So the suffix at the end is the same. Ends 090 then either nothing or a letter?
Hi, I finally have an update on my issue. Having hesitated to even swap the units because of bad coding I finally found a guy with ODIS who was able to put in the factory settings in the replacement unit. Lights are working as supposed to, internal lights are coming on as designed. The only thing is, that we were not able to adapt the keys. None! The VCDS fails to do that, and loses connection to the 09 address. ODIS finishes with fault, Delphi ends the procedure prematurely with unsuccessful note.
When I put in the original BCM unit, I am able to erase the keys and adapt them both just fine with VCDS. Is the replacement unit bad in another way? I know it was used before, but I was assuming it will be okay with my factory settings and my coding. It is also free of any errors.
Do you have any tips on what I can try next? Would it be even possible to repair the original BCM or use both simultaneously with some pins going to one and the rest to the other one? I am so confused right now that I am considering completely redoing internal lighting or getting aftermarket central locking system.
Thanks for all your help
The keys and immobilizer work with the dash clocks, as well as the bcm,/ecm.
So does the clocks need to be reset and added to the new bcm? Ie paired up.
I think all three units work together as a security feature to stop a bcm swap enabling unknown keys.
Huh, that is an interesting point. That might be paired with the Serial number of the BCM, right? If I have factory settings from ODIS, it only affects behavior, but apparently might not affect the unit pairing. If I understand it correctly.
Is this something I can do myself via VCDS? Probably in Gateway settings?
Thank you for your reply @Dellmassive.
I suspect my bcm 7e0937090 and I am tempted to swap it out.
Did you manage to solve your problems with the swap?
Or did you find someone to repair your original?
I am hoping I can just change the coding and a few adaption settings but ...
I would be grateful for any advice.
Colin
