yes, as long as you have the Multi-Function-Display between the large dials.So i just bought a Carista too
can i get the digi speedo on a 2016 startline van??
With Australian can I get it big on screen also?Depends on the model of your van if it will show folding mirrors or not, not all folding mirrors will do it automatically. As for the mph you have to change the region to Australian.
If its....It's a 2016 caravelle generation 6, has folding mirrors on the button. Am I going to needed vcds to do it?
With it being registered in June 2016 I'd imagine it'll be 2016MY. Balls looks like I'll need to find someone local with VCDSIf its....
MY2016 then it can be coded using VCDS to fold on comfort locking (long press and hold of the lock button)
MY2017 then it can't be coded and you need a separate folding module like this T6 Power Folding Mirror Upgrade Module & Switch Kit
MY2018 is already coded from the factory
Looks like when I do Australia it just changes everything to km instead of miles, and no big display am I missing som35hing in settings?With Australian can I get it big on screen also?
Brill, will try it now. It says will affect ext lights, will that affect drls or anythingOn your MFD change the units back to miles and tick alt/dist or something like that should give you big MPH
Brill, and no effect on drl or anything light related?@landy You have to convert the display from U.K. To Australia (on Carista). Then on the mfd go to settings. Untick alt speed dis, then go to mfd data and tick digit speed. Finally change consumption/dist units back to gallons/mph and job done![]()
No. You may have to have the bonnet open when coding to enable the changesBrill, and no effect on drl or anything light related?
