Hi All
So last year I bought a 2013 T5.1 BiTdi 4Motion LWB Kombi. It came fitted with an almost new set of KW Coilovers and the previous owner had fitted new top mounts etc and lowered it pretty much as low as they would go. I decided to lift it about 10mm and bought a set of new OE Sportline 18 alloys and fitted brand new Bridgestone All Season tyres.
Now I did not want to wear the tires out, so I then went to a local ( 30 min drive away ) to me garage that had a latest Hunter Geometry rig and I had heard good things about their.
service. When I got it back they said the rear was 80mm below standard ride height and the front 60mm. I did at the time find this hard to belive as the KW has a max lowering of 60mm and I was not at the max. Anyway they said everything was set geomntery wise and off I went thinking great that will stop my tyre wear.
Several months later and I go back to the same garage for my MOT and when I collect it they said, "you should take that back to where you got the geomtery done as it is scrubbing the insides of the front tires down to the legal limit" I SAID YOU DID IT!!!
They then back tracked and said that's coilover's for you and you cannot get things set right blah blah blah
So I guess I am hoping someone can give me some suggestions before I go back and question their work.
They did not tell me at the time that their geometry set up would cause wear, just it was fine. If they had said at the time due to your coilover's and we only set camber etc to OEM then I would have done something about it before it chewed through my tyres.
Do I need to fit something aftermarket to allow me to set the coilovers up correctly? Or should they be able to set it right as is?
Any help or guidance much appreciated.
Lee
ps i live in Braemar Aberdeenshire if anyone knows somewhere up in Scotland that is used to working on VW T5/T6 for this sort of thing please let me know.
Lee
