I used to fret about the bike(s) when sleeping and shoehorn them inside the van. Now I have an Atera rack, with locks and then used chains/cables to further secure them. Backing it up into bushes/walls makes it even harder for the wee feckers. If anyone has the nerve to go for that while I'm in the van, they deserve the bikes.Looks great for carrying the bikes - similar to the Amdro bed I was looking but with the sliding base which I really like - can't see the bikes fitting under when the bed is out though
What draw slide mechanism have you used. They look really heavy dutyI’ve finally finished laminating the last bits of ply to extend the rear platform into a bed/ loading area. I use the van for work and camping so wanted the fit out to be versatile and the platform load bearing though I do think I over engineered this a bit. The drawer is fantastic.
Looks ace, well done
looking to do somthing like that for the rear of my panel van to I can pull the draw out and cook under the tailgate rather than fitting a kitchen in the van
They’re from GSF slides. They have a lock in/lock out mechanism which I think is needed in a van, though I popped the spring out on one side so I didn’t have to lift the latch on both. They take 250kg, so yes heavy duty, though they have other higher load bearing slides. There’s also one which locks half way out, but they’re more pricey.What draw slide mechanism have you used. They look really heavy duty
I used 18mm poplar ply. I think 15mm would have been fine. It does add up in weight. Laminated with Formica. We have a vacuum bag press at work. If you’re in the West Country Saxon laminates can laminathe whole sheets for you. To be honest, if I did it again, I’d go down that route and send it off to be cnc cut.Can I ask how you laminated the ply abs what ply did you use?
That looks like a really flexible solution. Just built a bed platform for our 1st trip away in the Kombi and it worked great. Problem is when I want to throw the bike in the back without removing wheels I can’t do with the bed frame in meaning I have to take it out. So your solution of the removable top could be the answer.
Can see that you’ve fixed the side panels to the floor anchor points but wondering if you have them fixed to the side of the van as well ? Also how did you cut the profile on the rear to match the bulk head as it looks really neat.
Cheers! Maple should withstand a few knocksTop class work, and innovative. Particularly like the hardwood bull nose end cap. It's the detail that counts.
