So is my suggestion of a double pole MCB rated at say 20A for the main incoming switch (don't need an RCD because that will be covered by the RCBO's alongside it, 20A to avoid nuisance tripping over campsite breaker) and a few RCBO's with switched neutrals for each output to sockets a good option? Single busbar along the bottom, earth from campsite connection socket to van chassis and common earth rail in the consumer unit, earths to sockets connect here too, neutrals from DP 20A MCB and RCBO's to common neutral rail in consumer unit, Live to top of DP 20A MCB and busbar from bottom to RCBO live inputs at bottom. Then live and neutrals to sockets to tops of RCBO's.
