Is there a solution?
dereckerick
Hi All
I have a T6 Caravelle, all bells and whistles, bought it with 1300 miles as an ex demo and got 8K off. However, even though its got everything I could have wished for, its got yellow lights!!
Yes, I know there are numerous threads with what people have done and tried to rectify this issue, but is there a single place we can find what bulbs can replace what is fitted?
If i had ordered the van with my spec I would have paid for LED but with 3 screaming kids i needed the van quick and 3 weeks with a god deal did it for me.
If i bought the LED headlamp units how hard is it to fit them?
Forget LED, until an aftermarket kit comes out, until then Osram night breakers etc
How easy is it to change the bulbs? I've had a quick look and it looks tight space, do i have to remove alot of stuff, im crap at not breaking things and usually end up with spare bits
@dereckerick if you are fitting H4 extra power bulbs like the Osram Nightbreakers then it is straightforward I am told. The working space is tight so if you have large beefy hands you might be better off getting Mrs Dereckerick to do them for you :):).
As above, I found it tight, but just take your time.. Didn't need to remove anything special, just make sure you don't touch the bulb glass.. If you do, clean it and start again..
Caravelle is h7 bulbs..
Main bulbs easy to change.
Still yet to get some led drl ones that fit.
