tezwilliamson@googlemail.
Hi all, posting here in the hope that you guys can potentially help. Two weeks ago after a 140mile drive I stopped for a short break and the van wouldnt start (Kombi 2.0T6 Auto). RAC came, said battery was ok and no fault diagnostics. So recovery booked however 5 hours later when they arrived the mechanic driving said he would take a look, put his charger on battery for a about 2mins (although battery showing ok) and it started shortly after. We then tried it for 30mins on and off and no issue. On his suggestion I drove home 140mile without stopping (rather than have the van be put in a compound locally before recovery the next few days) and once I stopped on my drive it wouldn't start again. Next morning I rang RAC again who came out and this time when diagnostic machine was on it came up with "crank shaft sensor" and he got it going so off to the garage. Crank shaft sensor (cheap at 35 quid part) has been replaced along with a new battery (was showing low amps apparently). On return of the van its ran fine for 2 days on several journeys but now exactly the same issue. I was told that the crankshaft sensor fault only showed when it was failing and was no log in the diagnostics - as you can probably tell I ain't no mechanic
So I am stuck on my drive and will be calling RAC tomorrow but in the meantime thought I'd post here to see if anyone has any ideas. Long shot I know and thanks in advance.
