Hi all
Currently running this system on my 2017 T6 Euro 6:
CTEK 250SA DC-DC
Sargent EC155
Victron Smart Shunt
Victron MPPT 75/15
120w Solar Panel
System had been running fine, just back from a weekend away without issue, but on the school run yesterday the Sargent panel started alarming, the top right LED was also flashing green and I was unable to turn the Sargent on/off (engine running at the time). Turned engine off and Sargent stopped beeping and flashing, was able to switch on and everything working as normal.
I left it all day and when I went to do the school run pick up it was ok for about 10 mins and then started again. Turned off engine and all ok. So I checked the charging voltage on the Victron Smart Shunt app and could see (whilst the engine was running) it was putting out 15.20 volts, seems high? I kept the app open and when the voltage dropped below 15.0v the alarm stopped. So for some reason I suspect the CTEK is giving out too much voltage to the Sargent or there is an issue with the Sargent possibly? Not my area of expertise.
I thought it may have been to do with the freezing cold weather (read that Sargent's are temperamental in cold weather), but I ran the Planar for a good while to warm the van out, so not convinced this is the cause.
Any guidance appreciated.
TIA - Rik.
CTEK 250SA DC-DC
Sargent EC155
Victron Smart Shunt
Victron MPPT 75/15
120w Solar Panel
TIA - Rik.
