High Speed windscreen wiper not working
BDahmane
Hi
I have T6 2017, weird issue, the front wipers work fine for intermittent and medium speed but when I put it to highspeed, they stop, is this related to fuse or relay issue? any help would be appreciated. Thanks
Won’t be a fuse. Either a switch issue or motor. VCDS would be good to check switch inputs / fault codes.
Hi
Hi did you get to the bottom of this as I have the same issue on my 2019 T6
