My lads van had a bit of a fit this morning, EU5 T6. EML & glow plug lights came on, went into limp mode, gears not changing properly. Turned off and back on, run ok, no lights.
A few hiccups during the day, put on VCDS when he got back, gave these codes:-
4 Faults Found:
4807 - EGR System
P0401 00 [096] - Insufficient Flow
Intermittent - Not Confirmed - Tested Since Memory Clear
5172 - Boost Pressure Regulation
P0234 00 [096] - Limit Exceeded (Overboost Condition)
10065 - Mass Air Flow Sensor (G70)
P0104 00 [032] - Intermittent
5603 - Park/Neutral Switch Input Circuit
P0851 00 [100] - Short to GND
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 4
Mileage: 123616 km
Date: 2021.06.16
Time: 09:11:17
Engine speed: 953.00 /min
Normed load value: 50.2 %
Vehicle speed: 7 km/h
Coolant temperature: 89 °C
Intake air temperature: 37 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 13.120 V
Unlearning counter according OBD: 40
Accelerator pedal travel: 0.00 %
Accelerator pedal: sensor voltage 1: 740.6 mV
Accelerator pedal: sensor voltage 2: 364.8 mV
Accelerator pedal: switch positions-Bits 0-7: 9
Starter control: Interlock- or P/N-signal-Bits 0-7: 1
Limitation: torque: 91.9 Nm
Control Module temperature: 58.1 °C
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BT 300 046 G HW: 0BH 927 711 G
Component: DSG DQ500-7F H11 2502
Revision: 00H11V01
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_001_VW36.rod
VCID: 3A7B87EFBD5F905605-806E
2 Faults Found:
10632 - No Communication with Gear Selector Module
U0103 00 [172] - -
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 0
Fault Frequency: 13
Mileage: 123615 km
Date: 2021.06.16
Time: 09:10:33
Engine speed: 1291.00 /min
Vehicle speed: 255 km/h
Coolant temperature: 215 °C
selected gear: GANG_UNDEFINIERT
Engine torque: 120 Nm
Control Module temperature: 92 °C
Accelerator position: 31.2 %
DTC memory status: 255
10763 - Starter Enable from Selector Lever Sensor System
P1734 00 [044] - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Mileage: 123616 km
Date: 2021.06.16
Time: 09:11:16
Engine speed: 951.00 /min
Engine torque: 4 Nm
Control Module temperature: 90 °C
Accelerator position: 14.8 %
He has just driven it home, DSG not happy in auto but works fine in manual.
Any ideas where to start would be appreciated.
TIA
4 Faults Found:
4807 - EGR System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 123616 km
Date: 2021.06.16
Time: 09:11:17
Revision: 00H11V01
Coding: 0014
2 Faults Found:
U0103 00 [172] - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 13
Mileage: 123615 km
Date: 2021.06.16
Time: 09:10:33
P1734 00 [044] - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Mileage: 123616 km
Date: 2021.06.16
Time: 09:11:16
Engine torque: 4 Nm
TIA
