HELP PLS! What have i done...
NC35
Hi Everyone,
Be kind pls, complete noob to the T6.
I seem to have lost the current speed on the MFD. There is a small speed on the display, but in kmph. The units are UK MPH/ MPG
Yes, I was messing round with the settings! I think that everything is back to as it was.
Last resort will be factory reset. Though I wasn't absolutely sure what this would do.
If you previously had a large MPH display on the centre of the screen then you will have two speedo options in the menu
Cant remember exactly what they are called but think it 'alt speed' and digit speed' but you cant have them both active at the same time so untick the one you can see and the other option should reappear
Still no joy.
Even tried the factory reset.
It was a bit sluggish to turnover this morning, so wondering if the battery has let it down.
Any help please?
I have been reading the VCDS forum. It looks like you do, but it was working well yesterday.
So, need to dig out my cable and have a play!
Don't you have to set it to country code AU for the large MPH display?
Yes,
km/h will disappear as well after changing the country. Not sure if you can do it over the settings menu. I´ve done it with Carista.
Yeah, you have to use a dongle to set it. So is it set to country AU?
