Fitting RIB offset swivels and want to keep the seats as low as possible so I am modifying the handbrake bracket so that I don’t have to fit the spacers that came with the RIB swivels.
No problem drilling out the original spotwelds and grinding off the short weld on the back corner of the bracket.
Now, if I weld it back 20mm lower that’s not all the way down but lower than the thickness of the spacers.
Anyone done this? And is it a good idea to also move the bracket forward 20mm to take up some cable adjustment? I want to refit the OEM covers after cutting 20mm off the bottom of course.
