H7 Headlamp Deflectors And Position???
pezzas
Hi all,
I've already checked lots of threads so apologies if it has clearly been answered previously (emphasis on the "clearly") :)
Please can someone confirm their choice of deflector and position for a RHD please?
Note this is specifically for the H7 twin lamps.
Thanks,
Ad:confused:
Surely someone has gone through this before?
Off to France next week so keen to get this sorted:D
Let me know please, thanks:thumbsup:
Now you've said you're off to France I now know what you're on about.
You when the beam deflectors allowing your lights to comply when driving on the opposite side of the road.
My experience is limited but normally a cheap set do the job and they come with instructions. You only peel them off and throw them away after anyway.
I thought somehow you were asking about moving the actual reflecter behind the bulb.....
The best, cheapest, and most accurate way is drive squarely up to a wall about 10 feet away and use some black electrical tape to mask off the "uptick" from the dip beam.
If you will do this regularly, then purchase some of the clear clip-on headlamp protectors and add the tape to them so that they can me removed and replaced as required.
