naynay
Not seen this been discussed much if at all. Im looking at the pros and cons between each and coilover. These seems to be a huge amount of detail on the solows and very little on the H&R Deep kit.
This will largely targeted at a T32 camper so hub mods arnt an option. The Solow LOWS are priced at £1400 and the H&R Deep kit at a little over £2000. To me the H&Rs seem slightly better value with fronts using stainless steel bodies and them having a larger adjust range 40mm to 100mm or 130mm if you opt for the bigger drop version. Solow LOWS being 95mm to 125mm.
Has anyone else had any experience with the H&R Deep, comfortability etc?
